Normal Topic Diagram not working (Read 2369 times)
CODISMA
Diagram not working
Sep 26th, 2022 at 3:42pm
I just bought a licence of Diagram for ASP.NET, but unfortunately it's not working.
During my test I was using an old version, and since I loaded the last version (6.x), the Diagram is not showing (screenshot1.jpg).
If I modify the zoom factor of the web browser, then I can see some nodes but they are not enabled (gray) and I can't move them or draw new nodes (screenshot2.jpg).
Can someone help me please???
EDIT :
This happening only when  I use ClientSideMode="Canvas" .
Re: Diagram not working
Reply #1 - Sep 26th, 2022 at 4:07pm
Your license should also work for older versions, so you could revert to the one you were testing with and just set LicenseKey there. Otherwise please check for any API changes listed in respective what's new / version history help topics between current and test version - you might have to update your scripts for some of them. Please also report any errors you are seeing in browser console.
Reply #2 - Sep 26th, 2022 at 4:11pm
For canvas mode, make sure you've also updated the MindFusion.Diagramming.js script in your project with one from latest version.
CODISMA
Reply #3 - Sep 26th, 2022 at 4:30pm
Hi Slavcho,
Thank you for ur quick reply.
I bought a licence and I want to use it with the latest version.
Yes, the MindFusion.Diagramming.js script  is the latest one.
You can try with the Sample included in the installation folder :
C:\Program Files (x86)\MindFusion\MindFusion.Diagramming for ASP.NET\Samples\Samples\CSharp\Controls
You should have the same problem.
Thank you for your help  Smiley
Reply #4 - Sep 27th, 2022 at 8:49am
The Controls sample works for us. Please try clearing your browser's cache. Newer .net assemblies might not be compatible with an older diagramming.js if browser keeps using cached script. Please also check for error messages in console.
CODISMA
Reply #5 - Oct 5th, 2022 at 6:19pm
Finally I managed to make it work...I was using the wrong version of js file.
