Normal Topic MindFusion in Electron js (Read 1539 times)
Gadger
Oct 23rd, 2021 at 2:09pm
I'm trying to use the Electron js framework, with "MindFusion JsDiagram Sample - A Simple Diagram" as an example . I have a very simple "main.js" file that just creates the browser window. If I put all the MindFusion code into the HTM file inside <script> tags it works, but if I try to require or import the MindFusion library code into the "main.js" file the require/import fails. Is there a special way of loading "MindFusion.Diagramming.js" etc into an Electron app?
Re: MindFusion in Electron js
Reply #1 - Oct 23rd, 2021 at 2:26pm
With version 3 you can load the diagram scripts using only non-module <script> element and access the API through global MindFusion.Diagramming namespace object. E.g. see https://mindfusion.eu/blog/running-javascript-diagram-applications-with-electron...
You should be able to use import or require statements instead of global namespace with version 4 scripts here:
https://mindfusion.eu/Forum/YaBB.pl?num=1631794657
Gadger
Reply #2 - Oct 23rd, 2021 at 3:48pm
Thanks -- it sounds like Version 4 will be just what I need
