Normal Topic Change node position dynamically (Read 3932 times)
JaymeW
Nov 9th, 2021 at 4:39pm
I'm trying to create a function that makes a node able to iterate through a flowchart. So far I can access the position of nodes and store them in a variable. What I'm not getting is updating the node position to the next node in the flowchart.
Also, I need to delete the current node at the end of the flowchart so that the next one can enter it, is there a function that can delete specific nodes? I had thought about saving the current state of the flowchart and then deleting everything and loading the flowchart so the next part could come in, but that would be too much work for something simple I plan to do.
Below is an example, I want nodes A and B to go through the flowchart. When A finishes its course, it would be deleted and B would enter. When I refer to entering the flowchart it is simply superimposing the node on the node of the flowchart placing it in the same position.
Online
Re: Change node position dynamically
Reply #1 - Nov 9th, 2021 at 5:08pm
You can remove a node by calling Diagram.removeItem method.
var overlayNode;
var flowchartNode;
// using version 4 property syntax
function iterateNextNode()
	if (overlayNode == null)
		return;
	var nextNode = null;
	if (flowchartNode != null)
		for (var link of flowchartNode.outgoingLinks)
			nextNode = link.destination;
			break;
	else
		nextNode = diagram.nodes[0];
	if (nextNode == null)
		diagram.removeItem(overlayNode);
		overlayNode = null;
		// todo: select next overlay
	else
		overlayNode.bounds = nextNode.bounds;
	flowchartNode = nextNode;
JaymeW
Reply #2 - Nov 9th, 2021 at 5:50pm
thank you it's working, but the node's size is changing as it goes through the flowchart. How could I just take the position without changing the size?
Online
Reply #3 - Nov 9th, 2021 at 5:55pm
Clone overlay's bounds, call clone's Rect.setCenter method passing to it the target's center, and assign it back to overlay.bounds. Alternatively set Rect's x/y properties if you want to align node's sides instead of centers.
JaymeW
Reply #4 - Nov 11th, 2021 at 6:28pm
thank you. One last thing, I also researched that the library has an animation function, however, the node it can only traverse vertically? Whereas I only found examples in this model.
Online
Reply #5 - Nov 12th, 2021 at 7:50am
You could register a callback function that lets you animate different values than Y position. E.g. this is from Samples/JavaScript/Animations.js:
function createPulseAnimation(item) {
	var options =
		duration: 550,
		repeat: true,
		reverse: true,
		fromValue: -0.075,
		toValue: 0.075
	var a = new Animation(item, options, onPulse);
	return a;
// a custom update callback to create the pulsating effect.
function onPulse(animation, progress) {
	var bounds = animation.item.bounds.clone();
	var to = animation.toValue;
	bounds = DrawingUtils.inflate(bounds, to * progress, to * progress);
	animation.item.setBounds(bounds, true);
JaymeW
Reply #6 - Nov 12th, 2021 at 4:00pm
Thanks again  Smiley
JaymeW
Reply #7 - Nov 17th, 2021 at 4:40pm
I can animate a node and make it travel on the X axis and diagonally. However, my problem now is how to calculate the path that the node needs to go from one another diagonally. Is there any library function that, with the center of two nodes or using node bounds, I can calculate the path that the animated node needs to go?
Online
Reply #8 - Nov 17th, 2021 at 6:15pm
Position math should be the same as links' start-to-end-points animation from that example -
function onUpdateLink(animation, animationProgress) {
	var link = animation.item;
	var pointA = animation.fromValue,
		pointB = animation.toValue;
	link.endPoint = (
		new Point(
			pointA.x + (pointB.x - pointA.x) * animationProgress,
			pointA.y + (pointB.y - pointA.y) * animationProgress));
	link.invalidate();
So replace pointA and pointB with your node centers, and then move overlay node instead of setting link.endPoint.
JaymeW
Reply #9 - Nov 17th, 2021 at 7:40pm
It's works! Thank you Smiley
