Normal Topic LayeredLayout routing links issue (Read 2064 times)
Erwin Lackner
Jan 10th, 2022 at 12:19pm
we are using Diagramming.WinForms (6.6.0.451) and LayeredLayout now for a while and the implicit routing of the links via LayeredLayout.Arrange(diagram) works fine.
But now we have a scenario where the links doesn’t fit well and we can’t figure out other/better settings to get the expected results. Because of the many involved setting options i've provided/attached a testbed solution for reproduction of the problem.
Clicking TestGraph2 (180/120) shows the arrangement of the graph with node dimensions we use. Normally the nodes would show content, therefore this dimensions. The red marked links are not routed as we would like to have.
We figured out, that drawing the graph with small node dimensions (width 18px, height 12px) would route the links as expected (Click button TestGraph1 (18/12)), but we need the node dimensions as of TestGraph2.
We also figured out that calling Diagram.RouteAllLinks() after LayeredLayout.Arrange would shows the expected result, but using this strategy has drawbacks because it routes links different/suboptimal in other scenarios.
Any ideas how we could get the routing of the links as expected?
Erwin
Online
Re: LayeredLayout routing links issue
Reply #1 - Jan 11th, 2022 at 7:39am
LayeredLayoutLinkType.Cascading reuses points of default Straight type and just inserts bends halfway between layers, which happens to be exactly on node borders for your 120 node height and 60 layer distance values. You could pull links' first and last horizontal segments towards origin / destination nodes:
m_layout.Arrange(Diagram);
foreach (var link in Diagram.Links)
    var cp = link.ControlPoints;
    if (cp.Count > 4)
        int l = cp.Count - 1;
        cp[1] = new PointF(cp[1].X, cp[1].Y - m_layout.LayerDistance / 2);
        cp[2] = new PointF(cp[2].X, cp[2].Y - m_layout.LayerDistance / 2);
        cp[l-1] = new PointF(cp[l-1].X, cp[l-1].Y + m_layout.LayerDistance / 2);
        cp[l-2] = new PointF(cp[l-2].X, cp[l - 2].Y + m_layout.LayerDistance / 2);
Diagram.RoundedLinks = true;
Diagram.RoundedLinksRadius = 20;
Erwin Lackner
Reply #2 - Jan 14th, 2022 at 10:05am
Hi Slavcho,
thanks for your solution, looks great now Smiley
Your great support and quick response times helps a lot Smiley Smiley Smiley
Regards Erwin
