Normal Topic Diagramming for Windows Forms, V6.8.3 (Read 1695 times)
Jun 8th, 2022 at 10:31am
We have released version 6.8.3 of FlowChart.NET. It contains the following new features and improvements:
Multiple labels per node
The NodeLabel class allows multiple captions to be displayed for a single DiagramNode of any type. Node labels provide a set of properties allowing full customization of their display and positioning. Label position is defined by specifying a pin point and offset from it, set through SetCornerPosition, SetEdgePosition, SetCenterPosition methods. In addition, the HorizontalAlign and VerticalAlign properties of NodeLabel specify on which side of pin point to draw the label's caption.
For example, following code adds extra labels to top-left and bottom-right corners of a ShapeNode:
var node = diagram.Factory.CreateShapeNode(10, 50, 40, 30);
node.Text = "text"; // centered main text
var lb1 = node.AddLabel("label 1");
lb1.SetCornerPosition(0, 0, 0);
lb1.HorizontalAlign = StringAlignment.Near;
lb1.VerticalAlign = StringAlignment.Near;
lb1.Brush = new SolidBrush(Color.Red);
lb1.TextBrush = new SolidBrush(Color.White);
var lb2 = node.AddLabel("label 2");
lb2.SetCornerPosition(2, 0, 0);
lb2.HorizontalAlign = StringAlignment.Far;
lb2.VerticalAlign = StringAlignment.Far;
lb2.Brush = new SolidBrush(Color.Yellow);
lb2.TextBrush = new SolidBrush(Color.Red);
  • The MoveLabels behavior lets user move link and node labels interactively.
  • HorizontalOffset and VerticalOffset now work for link labels positioned using SetLinkLengthPosition method.
  • ExcelExporter exports pen width of links.
  • ExcelExporter sets more precise positions of link end points.
Updated assemblies are also available as MindFusion.Diagramming NuGet package.
