Normal Topic Index out of range error while dragging a particular Link/Node in the diagram (Read 2418 times)
chai2prince
Jun 17th, 2022 at 8:43am
I am using the Mindfusion WPF component and for a particular digram only, I am facing an issue. The issue is that when I drag a particular link from a flow diagram, I get a System.ArgumentOutOfRangeException. Attached is a screenshot of the error. Cannot share the diagram due to the non-disclosure agreement and sensitive data.
It would be great if someone can help resolve the error.
Re: Index out of range error while dragging a particular Link/Node in the diagram
Reply #1 - Jun 17th, 2022 at 9:48am
What version of the control are you using? There's fix for link-to-table exceptions listed in this release -
https://mindfusion.eu/Forum/YaBB.pl?num=1642078090
chai2prince
Reply #2 - Jun 20th, 2022 at 8:25am
Thanks for your prompt response.
We are using version 3.0.1.17264 for MindFusion.Diagramming.Wpf
I will try using the latest version to see if the error is resolved.
Thanks again.
chai2prince
Reply #3 - Jun 20th, 2022 at 4:03pm
I tried upgrading to 3.8.1 using nuget package. However, the issue is still occurring.
Reply #4 - Jun 21st, 2022 at 2:30pm
That link's OriginAnchor or DestinationAnchor index somehow became larger than respective table row's AnchorPattern.Points.Count. If your application changes row.AnchorPattern dynamically after links are already connected to the row, you might have to reset those indices too.
