Page Index Toggle Pages: 1 [2] 3  Send TopicPrint
Very Hot Topic (More than 25 Replies) Invoices (Read 7819 times)
Online
Re: Invoices
Reply #15 - Apr 3rd, 2023 at 5:47pm
That looks to be another difference between FromFile/Stream vs FromDictionary implementations. Probably XamlLoader used in former is not preparing the loaded content for binding and styling out of the box when non-WPF types are involved. Our developer will research the differences.
It seems you've reverted to loading the report back from embedded resource anyway? so you could as well load it using FromDictionary method as in original example.
Mandy
Re: Invoices
Reply #16 - Apr 7th, 2023 at 7:43am
Hi Slavcho,
1)The report will be dynamically loaded from an external source, so "FromStream" will be used to implement it.
2)When passing a value to "IValueConvert", the output window in VS2019 displays "BindingExpression path error".
This will slow down the execution speed of the report. Is there a way to resolve this issue?
3)The "FontSize/FontWeight" property in the "Style" is not working. How can it be set?
Online
Re: Invoices
Reply #17 - Apr 7th, 2023 at 8:33am
Hi Mandy,
2&3 work with FromDictionary version, so you might look for a way to get FromFictionary(url) load external files URLs; our developers could not when they looked into that last time though.
Mandy
Re: Invoices
Reply #18 - Apr 7th, 2023 at 11:32am
Hi Slavcho,
1)Can a URL be passed directly to "FromDictionary"?
For example: Report.FromDictionary("https://test.com/InvoicesReport1.xaml")
2)The file may be downloaded from the Internet and saved locally, can a path be specified?
For example:  Report.FromDictionary("C:/users/mandy/Downloads/InvoicesReport1.xaml")
Online
Re: Invoices
Reply #19 - Apr 7th, 2023 at 2:27pm
Hi Mandy,
FromDictionary is just a 'return Application.LoadComponent(uri) as Report':
https://learn.microsoft.com/en-us/dotnet/api/system.windows.application.loadcomp...
We could not find a way to load external file through that last time and implemented FromFile using XamlLoader, which apparently has some problems with binding expressions. Our developer will check these again in a few days.
Online
Re: Invoices
Reply #20 - Apr 7th, 2023 at 2:33pm
LoadComponent(uri) above links to this topic -
https://learn.microsoft.com/en-us/dotnet/desktop/wpf/app-development/wpf-applica...
so you might be able to make FromDictionary work by declaring a placeholder xaml file as Content file, overwrite it with the external file when you need to load report from one, and than call FromDictionary(content_placeholder_uri).
Online
Re: Invoices
Reply #21 - Apr 10th, 2023 at 4:05pm
Text="{Binding OrderID}" works if you also set DataSource="{Binding Orders}" on the DataRange element; it was commented out. The converter then works too -
Text="{Binding Path=OrderDate, Converter={StaticResource MyDateFormatConverter}, ConverterParameter='yyyy-MM-dd'}"
Mandy
Re: Invoices
Reply #22 - Apr 18th, 2023 at 8:37am
Hi Slavcho,
1)Is it possible to download XAML from the internet and load it into a report besides Content file and LoadComponent?
2)「so you might be able to make FromDictionary work by declaring a placeholder xaml file as Content file, overwrite it with the external file when you need to load report from one, and than call FromDictionary(content_placeholder_uri).」=>Do you have any example that I can refer to?
Regards.
Online
Re: Invoices
Reply #23 - Apr 18th, 2023 at 10:43am
Hi Mandy,
Forget about placeholder, just return back the DataSource="{Binding Orders}" for parent DataRange as in original example. It works for us with external files too then.
Mandy
Re: Invoices
Reply #24 - Apr 19th, 2023 at 3:24am
Hi Slavcho,
I am trying to load a report using two methods: FromDictionary and FromStream.
Here is my project:
https://drive.google.com/file/d/1R4peE9AowoJ5mdFFACr91gMc6X9QkpxJ/view?usp=shari
ng
"BindingExpression path error". => This will slow down the execution speed of the report.
Both of these methods will display an error message as shown in the following image
Online
Re: Invoices
Reply #25 - Apr 20th, 2023 at 3:16pm
Hi Mandy,
Path error is WPF thing and nothing to do with the report. {Binding PropertyName} works if the data object actually has such property, so you could create strongly-typed models for your data rows if you need to use exactly that syntax. Otherwise DataRow itself does not expose the columns as properties, and you must use [] indexers to access them -
https://stackoverflow.com/questions/4174906/how-do-you-bind-a-datarow-to-a-textb...
e.g. Binding Path=[ShippedDate] ...
Online
Re: Invoices
Reply #26 - Apr 20th, 2023 at 4:08pm
Hi Mandy,
Try this build for font styles -
https://mindfusion.eu/_temp/label_style.zip
Mandy
Re: Invoices
Reply #27 - May 2nd, 2023 at 11:35am
Hi Slavcho,
1)The font style works, Thank you.
2)Is there any way to bypass path errors other than creating strongly-typed models?
Mandy
Online
Re: Invoices
Reply #28 - May 3rd, 2023 at 5:07am
Hi Mandy,
Warnings are displayed by XamlReader.Load /  ItemTemplate.LoadContent methods before the report has the chance to apply data context to loaded elements. If {Binding} messages bother you that much, use the original Text="[OrderID]" syntax we show in sample projects.
Mandy
Re: Invoices
Reply #29 - Jul 5th, 2023 at 3:03am
Hi Slavcho,
Is there any way to keep the DataRange.HeaderTemplate displayed even if the data is empty?
Mandy
