Normal Topic Bitmap inside <image> is not display (Read 2805 times)
nullable
Aug 25th, 2022 at 10:41am
Hi, I have an svg file(https://dropmefiles.com/sY0gq) that contains a bitmap image in the <image> tag in addition to the primitives, and I'm trying to display this svg on a diagram using the code below,
the image, unlike primitives, is not displayed
var svgNode = new SvgNode();
SvgContent content = new SvgContent();
content.Parse(@"C:\Users\User\Documents\test2.svg");
svgNode.Content = content;
diagram.Nodes.Add(svgNode);
Re: Bitmap inside <image> is not display
Reply #1 - Aug 25th, 2022 at 11:03am
Indeed, SvgContent does not load bitmaps at this time. We'll have it in mind for next release.
Reply #2 - Sep 23rd, 2022 at 12:18pm
Try this build -
https://mindfusion.eu/_beta/wpfdiag383.zip
Ivan K.
Reply #3 - Nov 29th, 2022 at 11:57am
Hi All! Thank you for elaboration.
Unfortunately, SVG import does not work as expected.
If image has transform matrix - transformation is not applied on the resulting diagram. Could you please check?
Sample SVG: https://dropmefiles.com/53tYz
Code (Java)
content.Parse(@"D:/personal/img.svg");
Ivan K.
Reply #4 - Dec 6th, 2022 at 1:10am
Reply #5 - Dec 6th, 2022 at 8:42am
This build applies image transform -
https://mindfusion.eu/_beta/wpfdiag39.zip
