Normal Topic Scheduling for WinForms V5.8.2 (Read 3150 times)
Oct 10th, 2022 at 2:03pm
We have released version 5.8.2 of MindFusion.Scheduling for WinForms. The new version includes:
.NET 6 assemblies
The distribution now includes assemblies for .NET 6. Locally installed assemblies don't show automatically in toolbox at this time, you can either add them manually or through Nuget package manager.
Reorder resources
  • Enable the AllowReorderResources property of TimetableSettings to let users reorder resource columns in timetable view when GroupType is set. The ReorderIndicatorColor and ReorderIndicatorWidth properties let you customize the appearance of insertion indicator line.
  • Enable the AllowReorderResources property of ResourceViewSettings to let users reorder rows in resource view when GroupType and SecondaryGroupType are set. The ReorderIndicatorColor and ReorderIndicatorWidth properties let you customize the appearance of insertion indicator line.
  • New ItemHeaderText and ItemDescriptionText members of CustomDrawElements let you custom-draw item's text labels.
  • Enable the ExtendedCurrentTimeMarker property of TimetableSettings or TimelineSettings to make current-time marker span the full extent of timetable / resource view (instead of only header area).
API changes
AllowMoveRowHeaders property of ResourceViewSettings is now considered obsolete and superseded by AllowReorderResources. The latter also allows reordering secondary resources.
https://www.mindfusion.eu/PlannerTrial.zip
Updated assemblies are also available as MindFusion.Scheduling NuGet package.
