Normal Topic Opacity of images in exported svg does not parsed in svg node (Read 992 times)
nullable
Dec 14th, 2022 at 7:32am
Already mentioned this issue in https://mindfusion.eu/Forum/YaBB.pl?num=1670288989/0#0 but I think it is better to make separate topic. The issue is when I export svg with image inside and if this image has opacity 0.5, then opacity does not applied to the image when I try load it back. Could you please check it?
Re: Opacity of images in exported svg does not parsed in svg node
Reply #1 - Dec 14th, 2022 at 2:28pm
nullable
Reply #2 - Dec 23rd, 2022 at 10:11am
Hi, images works fine, but it seems like svg have same issue. I parsed svg in attachments with code below and opacity didn't applied. Could you please validate that?
var svgNode = new SvgNode();
SvgContent content = new SvgContent();
content.Parse(@"E:\WThings\ats\atsExport.svg");
svgNode.Content = content;
svgNode.Resize(500, 500);
Nodes.Add(svgNode);
svgNode.Transparent = true;
Reply #3 - Dec 26th, 2022 at 7:27am
New build here should apply it to other elements -
https://mindfusion.eu/_beta/wpfdiag39.zip
