Normal Topic Customizing the look and feel of links (Read 1474 times)
dpru2
Dec 20th, 2022 at 9:45pm
I'd like to customize the look and feel of links on my diagram. Overall the default style isn't bad - at the moment I just want to customize the thickness and color of the links.
I've tried two ways of doing this. First, on my diagram object I have the following line of code:
Code (C++)
diagram.LinkBrush = new SolidBrush(Color.FromRgb(255, 0, 0));
This didn't have any effect on the color of the links. However, I did notice that the LinkBrush property is now obsolete, so I tried the suggested way of using a theme. This is my code for that:
Code (C++)
MindFusion.Diagramming.Theme diagram_theme = new MindFusion.Diagramming.Theme();
MindFusion.Diagramming.DiagramLinkStyle diagram_link_style = new MindFusion.Diagramming.DiagramLinkStyle();
diagram_link_style.Stroke = new SolidBrush(Color.FromRgb(255, 0, 0));
diagram_link_style.StrokeThickness = 1;
diagram_theme.RegisterStyle(typeof(MindFusion.Diagramming.DiagramLink), diagram_link_style);
diagram.Theme = diagram_theme;
This also didn't seem to have any effect on the links in my diagram. Currently the default color of the links is a dark green color (as seen in the attached image).
For now this is all I am trying to accomplish, however, in the future I'd actually like to have custom link styles based upon the nodes that the link is connected to. I assume that in order to do this, I'll likely need to set the CustomDraw property of the diagram? Or handle the DrawLink event?
dpru2
Re: Customizing the look and feel of links
Reply #1 - Dec 20th, 2022 at 11:05pm
So, here's an update:
I went ahead and decided to handle all drawing of links, so I implemented this code:
Code (C++)
this.LinkCustomDraw = CustomDraw.Full;
this.DrawLink += MyDiagram_DrawLink;
And then I implemented the following function to draw links:
Code (C++)
private void MyDiagram_DrawLink(object sender, DrawLinkEventArgs e)
    Color pen_color = DeterminePenColor();
    Pen drawing_pen = new Pen(pen_color);
    drawing_pen.LineJoin = MindFusion.Drawing.LineJoin.Round;
    drawing_pen.Width = 2;
    var graphics = e.Graphics;
    graphics.DrawLines(drawing_pen, e.Points);
Overall the code is working well. The colors and line thickness are as I expect them to be. However, I was expecting the line segments to be joined with "rounded" line-endings, but as you can see in the attached image, the line-joins are not rounded. They are flat.
Any suggestions on fixing that?
Online
Reply #2 - Dec 21st, 2022 at 12:23pm
DiagramLink.Brush initialized from LinkBrush is used to fill arrowheads. Try setting LinkPen or DiagramLink.Pen instead. Make sure link's Brush / Pen are null in order to query values from styles or themes.
We'll check joints in DrawLines for next release. For time being try if DrawPath works better.
Online
Reply #3 - Jan 2nd, 2023 at 6:05am
New build here should fix line joints:
https://www.nuget.org/packages/MindFusion.Diagramming.Maui/
