Normal Topic Help needed implementing LoadFromXML for a DockControl in WPF (Read 4243 times)
MavinTech
Mar 15th, 2023 at 2:19pm
I am working with a WPF DockControl element.  I have a DockControl with multiple DockItems in it and called SaveToXml and it created an XML file, as expected.  When I call the LoadFromXml, nothing appears to happen.  I have read that I may need to override the load somehow and recreate the dockitems.  In the end, I need the user of the control to be able to manipulate the DockItems to their desired configuration, and then load that back up the next time they use the control.  I have included the XML file that the Save created.
Re: Help needed implementing LoadFromXML for a DockControl in WPF
Reply #1 - Mar 15th, 2023 at 4:42pm
Try handling the ItemLoading event. The DockControl sample project from WPF Pack distribution handles that to implement the "Load Layout" menu.
MavinTech
Reply #2 - Mar 16th, 2023 at 5:08am
Ok, that now works, thank you.
Is there a way to load the DockControl from an XML string that is read in from a database rather than from an external file?
Reply #3 - Mar 17th, 2023 at 7:14am
try this -
var xmlDoc = new XmlDocument();
xmlDoc.LoadXml(xmlString);
dock.LoadFromXml(xmlDoc);
