Normal Topic Diagramming for .NET MAUI, V1.0 (Read 3373 times)
Mar 24th, 2023 at 9:05am
MindFusion.Diagramming is now available for .NET MAUI. Currently supported targets are Windows, macOS, iOS and Android.
The nuget package is located at:
https://www.nuget.org/packages/MindFusion.Diagramming.Maui/
Distribution including sample projects and help files is available here:
https://mindfusion.eu/Maui.Diagram.zip
Call the UseMindFusionDiagramming extension from CreateMauiApp to configure the library:
namespace DiagramMauiApp;
using MindFusion.Diagramming;
public static class MauiProgram
    public static MauiApp CreateMauiApp()
        var builder = MauiApp.CreateBuilder();
        builder
            .UseMauiApp<App>()
            .UseMindFusionDiagramming()
        return builder.Build();
In order to use MindFusion.Diagramming types in Xaml, import the "http://mindfusion.eu/diagramming/maui" namespace schema:
<?xml version="1.0" encoding="utf-8" ?>
<ContentPage
    xmlns="http://schemas.microsoft.com/dotnet/2021/maui"
    xmlns:x="http://schemas.microsoft.com/winfx/2009/xaml"
    xmlns:diag="http://mindfusion.eu/diagramming/maui"
    x:Class="DiagramMauiApp.MainPage">
    <Grid>
        <diag:DiagramView x:Name="diagView" />
    </Grid>
</ContentPage>
Unlike the Xamarin diagramming library, in .NET MAUI version the Diagram is just a model class, and can only be shown using DiagramView. Other than that, the Xamarin and MAUI libraries have the same API.
public MainPage()
	InitializeComponent();
	var df = diagView.Diagram.Factory;
	var node1 = df.CreateShapeNode(10, 10, 30, 30);
	node1.Text = "Hello";
	var node2 = df.CreateShapeNode(60, 25, 30, 30);
	node2.Text = ".NET MAUI";
	df.CreateDiagramLink(node1, node2);
« Last Edit: Nov 7th, 2023 at 10:51am by Forum Admin »
