Normal Topic Calling offset method when rectangle is empty. (Read 1291 times)
nullable
Apr 3rd, 2023 at 8:04am
Hello mindfusion team!
I just wanted to know if there is possibility of avoiding empty rectangles when calling method Rect.Offset() in SvgExporter.Export()? I get the following exception when all diagram items don't have empty bounds and don't have NaN height or width.
2023-03-28 11:05:29.8787|Fatal|Unexpected error occurred. | System.InvalidOperationException: Cannot call this method on the Empty Rect.
   at System.Windows.Rect.Offset(Double offsetX, Double offsetY)
   at MindFusion.Diagramming.Wpf.Export.SvgExporter.(DrawingGroup , Transform , Geometry , Geometry )
   at MindFusion.Diagramming.Wpf.Export.SvgExporter.(Visual , Geometry )
   at MindFusion.Diagramming.Wpf.Export.SvgExporter.(Visual , Transform , Geometry )
   at MindFusion.Diagramming.Wpf.Export.SvgExporter.(Diagram , String )
   at MindFusion.Diagramming.Wpf.Export.SvgExporter.Export(Diagram diagram, Stream stream)
Re: Calling offset method when rectangle is empty.
Reply #1 - Apr 4th, 2023 at 10:30am
SvgExporter calls that only on GlyphRun boundaries and we can't think of why would be empty. Please post exact text and font with which you are seeing the error.
nullable
Reply #2 - Apr 6th, 2023 at 4:59am
Nevermind. It turned out the problem was with text with "-" symbol and whitespaces around it. For example, "text - text" caused this error during exporting, but it seems you've fixed it. Well done Wink
