Normal Topic How to Create a Node when the Canvas is clicked (Read 1047 times)
alukes
Jun 28th, 2023 at 12:23pm
I can get the context menu to appear at the correct location using the code below.
When I use point.x and point.y to create a node, the node is far away from where the canvas was clicked. How do I get the node to appear where the canvas was clicked?
function onClicked(sender, args) {
var point = diagramView.docToClient(args.mousePosition);
contextMenu.style.display = "block";
           contextMenu.style.left = `${point.x}px`;
           contextMenu.style.top = `${point.y}px`;
Re: How to Create a Node when the Canvas is clicked
Reply #1 - Jun 28th, 2023 at 3:25pm
Create it at the original args.mousePosition reported for the event. It's specified in diagram's measureUnit, which is used for item coordinates too. You need the converted point only for menu DIV's pixel offset.
alukes
Reply #2 - Jun 28th, 2023 at 7:34pm
Thanks for the explanation.
It works
