Normal Topic How to undo the command during ItemModified event ? (Read 1316 times)
Mandy
Oct 23rd, 2023 at 5:17am
I want to undo the change command when db update failed.
 private void Calendar_ItemModified(object sender, ItemModifiedEventArgs e)
	   var item = e.Item;
            var executeUndo = false;
            MindFusion.Scheduling.Item appChangeItem = item;
            MindFusion.Scheduling.Schedule appSchedule = this.calendar.Schedule;
            MindFusion.Scheduling.ChangeItemCommand appChangeCommand = null;
            this.calendar.BeginInit();
            appSchedule.UndoEnabled = true;
            appSchedule.StartCompositeOperation();
            appChangeCommand = new MindFusion.Scheduling.ChangeItemCommand(appSchedule, appChangeItem);
            //I want to undo the change command when db update failed.
            executeUndo = true;
            appSchedule.ExecuteCommand(appChangeCommand);
            appSchedule.CommitCompositeOperation();
            if (executeUndo)
                appSchedule.Undo();
            appSchedule.UndoEnabled = false;
            this.calendar.EndInit();
Re: How to undo the command during ItemModified event ?
Reply #1 - Oct 23rd, 2023 at 8:21am
Hi Mandy,
From this code it seems you are enabling undo only in ItemModified event handler, and at that point item's original times have already changed and old values discarded. If you keep UndoEnabled set from the start of the application, the control would record a ChangeItemCommand automatically anyway just before raising ItemModified event - then the handler could just call Undo when it detects errors in DB code.
Alternatively, if you don't want to rely on undo for that, you could record item's original times from ItemStartModifying event handler, and restore them from ItemModified if there's DB error.
Reply #2 - Oct 23rd, 2023 at 8:44am
Now I'm seeing ItemModifiedEventArgs also reports OldStartTime and OldEndTime, so instead of undoing from ItemModified, you could assign the old values back to the item.
Mandy
Reply #3 - Oct 24th, 2023 at 7:36am
Hi Slavcho,
I already set UndoEnabled = true at the beginning.
1)Click "Create" button to create a recurring appointment.
2)Checked the "Undo" checkbox.
3)Drag the item of 10/9 to 10/11.
The ItemModified event should be restored the items to 10/9, but now all items have been cleared.
Reply #4 - Oct 25th, 2023 at 4:47am
Hi Mandy,
Calendar's UndoManager is still recording an internal composite command for the change at this time and won't allow immediate undo. You could use InvokeAsync to undo after the mouse event handler:
Dispatcher.InvokeAsync(() => calendar.Schedule.Undo());
Or otherwise reset back to the Old*Time values provided as event arguments.
