Normal Topic move edit box below the node (Read 2246 times)
KrzysztofM
Nov 21st, 2023 at 12:04pm
Hi team,
My requirement is to display text below the node shape, and managed to do that by editing the setTextArea code from following post:
However, when the node is double-clicked, edit box still appears on top of the node rectangle. Is there any way to move that to the position of text below?
Thanks a ton.
KrzysztofM
Re: move edit box below the node
Reply #1 - Nov 21st, 2023 at 12:05pm
since it did not allow me to link in first post:
https://mindfusion.eu/Forum/YaBB.pl?num=1425413369/3#3
Reply #2 - Nov 22nd, 2023 at 10:00am
You could move the JTextArea from enterInplaceEditMode event handler -
void enterInplaceEditMode(InPlaceEditEvent e)
	JTextArea textCtrl = (JTextArea)e.getEditControl();
	textCtrl.setLocation(
		textCtrl.getLocation().x,
		textCtrl.getLocation().y + textCtrl.getSize().height);
If you are using a recent version of the control, currently we'd recommend adding NodeLabels to show texts outside the node -
NodeLabel lb2 = node.addLabel("label 2");
lb2.setEdgePosition(2 /*bottom edge */, 0, 2 /*offset*/);
lb2.setHorizontalAlign(Align.Center);
lb2.setVerticalAlign(Align.Near);
KrzysztofM
Reply #3 - Nov 24th, 2023 at 11:55am
Hi Slavcho,
We are too invested in using Text values, but will look into labels for our next planning. Regardless, InplaceEditMode method works great for us - thanks for that!
BR
