Normal Topic Highlighting Nodes Attached to Links (Read 270 times)
Nobu
Feb 16th, 2024 at 11:02am
How do I highlight a node attached to a link?
The nodes attached to the link are ControlNode and CompositeNode.
Tried and tested method:
When the link is selected, set the property (Selected) of the node attached to the link to true.
However, the LinkModifying event does not occur and I cannot move the destination or source of the connection.
Re: Highlighting Nodes Attached to Links
Reply #1 - Feb 16th, 2024 at 11:55am
Once you select multiple items, you get SelectionMoving event when they are moved, and links' origin / destination cannot change through a multiple-selection. You could draw highlights from DrawForeground event handler instead of selecting attached nodes:
void OnDrawForeground(object sender, DiagramEventArgs e)
	foreach (var link in diagram.Selection.Links)
		if (link.SubordinateGroup != null)
			foreach (var attached in link.SubordinateGroup.AttachedNodes)
				var rect = attached.Bounds;
				rect.Inflate(2, 2);
				e.Graphics.DrawRectangle(Pens.Green, rect);
				//or attached.DrawHandles()
Nobu
Reply #2 - Feb 16th, 2024 at 2:28pm
I tried it as soon as possible.
It works as expected.
Nobu.
