Normal Topic Evaluating control (Read 670 times)
icabeza
Evaluating control
Feb 27th, 2024 at 12:15pm
We are evaluating the nugget in the trial version and we have found several things that we need to know if you are aware of:
1. When creating a node in the control with a page as a Cavas, and try to move the node close to the limit of the page, it starts lighting trying to calculate the new canvas to pain. I have attached a picture of the situation, if I start moving the shape, it start flshing on the grey part.
2. The sroll bars are not shown the the element are in negative positions. Sometimes, It also happens when the zoom is performed, between the 70% and the 80% of the size.
Re: Evaluating control
Reply #1 - Feb 27th, 2024 at 12:57pm
If you mean you want to remove the gray part, make sure your starting diagram.Bounds is large enough to cover the view. You should be able to scroll to elements moved to negative coordinates (over left / top edges) by setting the AutoResize property to AllDirections. If you meant different problems, please attach a saved diagram XML or a test project demonstrating them.
