Normal Topic use Enter Key to submit my node inliine edit argument? (Read 1917 times)
SAN
Mar 1st, 2024 at 7:50am
I want to use Enter Key to submit my node inline edit argument. When I try to submit it I run into issue with the Arg type not matching. Any fix for this?
Online
Re: use Enter Key to submit my node inliine edit argument?
Reply #1 - Mar 1st, 2024 at 7:53am
Fix for what exactly? What do you mean by submitting and Arg type not matching?
SAN
Reply #2 - Mar 1st, 2024 at 8:01am
I am trying to use catch the textbox to submit the value by adding an eventlistener  but when I try to submit it checks the node event args
SAN
Reply #3 - Mar 1st, 2024 at 8:02am
Would Like to know is there is any other way you suggest to do this
Online
Reply #4 - Mar 1st, 2024 at 8:38am
Please post the event listener code.
SAN
Reply #5 - Mar 1st, 2024 at 10:13am
I just need a way if it's possible for enterkey to submit the value of the text instead of switching to nexyt line
Online
Reply #6 - Mar 1st, 2024 at 10:31am
try this -
diagramView.addEventListener(
    Events.enterInplaceEditMode, function (sender, args)
        args.control.addEventListener(
            'keydown', function (e)
                if (e.keyCode == 13)
                    sender.endEdit(true);
            }, false);
Online
Reply #7 - Mar 7th, 2024 at 2:20pm
We have a property for this on other platforms and implemented it in this version -
https://mindfusion.eu/_beta/jsdiag442.zip
diagramView.inplaceEditAcceptOnEnter = true;
SAN
Reply #8 - Mar 11th, 2024 at 10:42am
Works now thanks
