Normal Topic When operating the mouse wheel in DiagramView, internal parts move sideways. (Read 823 times)
koichi_satoh
Mar 8th, 2024 at 6:07am
Setting "AutoScroll = false" in DiagramView did not fix the problem.
This problem seems to occur when the width of the internal part exceeds the width of the parent DiagramView.
Please advise me on how to solve this problem.
Re: When operating the mouse wheel in DiagramView, internal parts move sideways.
Reply #1 - Mar 8th, 2024 at 7:04am
DiagramView.MouseWheelAction value is set to Scroll by default. It scrolls vertically if diagram.Bounds is higher than the viewport, otherwise it scrolls horizontally with lower priority if diagram.Bounds is wider. It also scrolls horizontally if Alt modifier is pressed. You can disable all that by setting MouseWheelAction to None.
koichi_satoh
Reply #2 - Mar 8th, 2024 at 9:27am
I solved it thanks to your advice.
thank you very much.
