Normal Topic link above the container node is not clickable (Read 1034 times)
Nobu
Mar 9th, 2024 at 2:23pm
When I click on the link, the ContainerNode is selected.
Is there a way to click on a link in a ContainerNode?
Is the only way to achieve this with the following code?
private void diagram1_NodeClicked(object sender, NodeEventArgs e)
	Log(sender,"NodeClicked");
	if (e.Node is ContainerNode)
        var link = diagram1.GetLinkAt(e.MousePosition, 1.0f);
        if(link != null)
            if(Control.ModifierKeys == Keys.None)
				diagram1.Selection.Clear();
            link.Selected = true;
Re: link above the container node is not clickable
Reply #1 - Mar 9th, 2024 at 3:13pm
Try setting diagram.HitTestPriority = ZOrder;
Nobu
Reply #2 - Mar 9th, 2024 at 3:45pm
I was able to do it!
Nobu
