Normal Topic How to create a Link other than drag-and-drop (Read 949 times)
Nobu
Mar 26th, 2024 at 1:41am
Is it possible to create a Link while clicking on the View as shown in the attached figure?
Re: How to create a Link other than drag-and-drop
Reply #1 - Mar 26th, 2024 at 7:52am
You could collect link points from DiagramView's mouse events -
bool linkFromClicksMode = true;
DiagramLink linkFromClicks = null;
void diagramView_MouseUp(object sender, MouseEventArgs e)
    var diagramPoint = diagramView.ClientToDoc(e.Location);
    if (linkFromClicksMode)
        var node = diagram.GetNodeAt(diagramPoint);
        if (linkFromClicks == null)
            linkFromClicks = diagram.Factory.CreateDiagramLink(diagramPoint, diagramPoint);
            if (node != null)
                linkFromClicks.OriginConnection = node.CreateConnectionPoint(
                    linkFromClicks, diagramPoint, false);
                linkFromClicks.StartPoint = node.GetNearestBorderPoint(diagramPoint);
        else
            linkFromClicks.EndPoint = diagramPoint;
            if (node != null)
                linkFromClicks.DestinationConnection = node.CreateConnectionPoint(
                    linkFromClicks, diagramPoint, true);
                linkFromClicksMode = false;
                return;
            linkFromClicks.ControlPoints.Add(diagramPoint);
            linkFromClicks.UpdateFromPoints();
void diagramView_MouseMove(object sender, MouseEventArgs e)
    if (linkFromClicks != null)
Nobu
Reply #2 - Mar 26th, 2024 at 9:29am
Thank you for your answer.
I will give it a try.
regards,
nodu
