Normal Topic About Routing Link (Read 914 times)
Nobu
About Routing Link
Mar 18th, 2024 at 5:31am
The link may extend beyond the borders of the DiagramView or ContainerNode.
Is there any way to suppress this phenomenon?
Re: About Routing Link
Reply #1 - Mar 18th, 2024 at 6:44am
If this shows links routed by default LinkRouter, you could assign smaller PreferredDistance value to the PatternRouter instance in routers chain:
var cr = diagram.LinkRouter as CompositeRouter;
if (cr != null)
	var pr = cr.Routers[0] as PatternRouter;
	if (pr != null)
		pr.PreferredDistance = 5;
Or otherwise you could set larger ContainerNode.Margin value so it leaves more space around child nodes.
Alternatively, we have some handling of ContainerNodes in GridRouter, so you could replace the LinkRouter instance:
diagram.LinkRouter = new GridRouter();
but it does not create as nice routes in the general case. We plan to add ContainerNode handling to default PatternRouter in near future.
Nobu
Reply #2 - Mar 21st, 2024 at 2:18pm
Thank you for your answer.
Nobu
