Normal Topic Diagramming for WPF, V4.1.1 (Read 549 times)
Jul 3rd, 2024 at 7:11am
We have released version 4.1.1 of WPF Diagramming library. It contains the following new features and improvements:
Export XPS files
The XpsExporter class from MindFusion.Diagramming.Wpf.XpsExport.dll assembly exports diagrams to XPS (XML Paper Specification) files. The Export method overloads let you export either Diagram or DiagramDocument objects.
  • The ToolTipDelay property lets you specify the delay in milliseconds before showing an item's tool-tip.
  • You can now control node's position during user interaction by setting OverrideBounds from NodeModifying event handler.
  • DiagramLink tool-tip fixes.
  • Fix for node presenter not disappearing until next WPF layout pass if UIElement.UpdateLayout is called from NodeDeleted.
  • Fixed ContainerNode rotation when RotationStep is set.
  • Fixed ContainerNode rotation for children added using GroupAnchorStyles or AttachToNode flags.
Updated assemblies are also available as MindFusion.Diagramming.Wpf NuGet package.
