Normal Topic Diagramming for WPF, V4.1 (Read 812 times)
May 31st, 2024 at 7:34am
We have released version 4.1 of WPF Diagramming library. It contains the following new features and improvements:
Support for custom in-place edit controls
Handle the CreateEditControl event to display a custom WPF control for users to edit item's content. This event is raised when entering in-place editing mode, either interactively by users or by calling the BeginEdit method. You could handle the event to return a composite control for editing many of the item's properties, and not only text. When leaving in-place editing mode, the DiagramView raises DestroyEditControl to let you copy to the item any values entered by the user and close the custom editor
New mouse events
  • NodePointerEnter and NodePointerLeave are raised when the mouse pointer respectively enters or leaves the boundaries of a node. NodeHovered fires if the pointer rests over a node for HoverDelay milliseconds.
  • LinkPointerEnter and LinkPointerLeave are raised when the mouse pointer respectively enters or leaves the boundaries of a link. LinkHovered fires if the pointer rests over a link for HoverDelay milliseconds.
  • ScrollWheelDelta and ScrollClickDelta properties let you customize the amount by which the view scroll position changes when users scroll using the mouse wheel or by clicking scrollbar arrows.
  • Handle the CreateToolTipControl event to create custom ToolTip instances.
  • AutoHandlesItem and AutoAnchorsNode properties return the items that currently display automatic adjustment handles or anchor points.
  • Fixed SvgExporter and PdfExporter memory leaks.
  • Fixed exceptions in SvgExporter for some text symbols.
API changes
  • The TextBox property of InPlaceEditEventArgs has been renamed to EditControl, and its type changed from TextBox to base Control type.
Updated assemblies are also available as MindFusion.Diagramming.Wpf NuGet package.
