Normal Topic I want to lay out a hierarchical structure using ContainerNode (Read 200 times)
koichi_satoh
Jul 16th, 2024 at 8:29am
As shown in the attached image, is there any way to display tree-structured data hierarchically using ContainerNode other than manually specifying Bounds?
I would like to create a layout without complex calculations, for example by using MindFusion.Diagramming.Layout, without having to implement logic to adjust the size of the parent ContainerNode according to the number of child ContainerNodes.
Online
Re: I want to lay out a hierarchical structure using ContainerNode
Reply #1 - Jul 16th, 2024 at 8:35am
This looks like the TreeMap sample project. Try the TreeMapLayout class shown there.
MindFusion
koichi_satoh
Reply #2 - Jul 17th, 2024 at 8:05am
Thanks to you, the problem has been solved.
Thank you very much.
