Normal Topic I want to lay out a hierarchical structure using ContainerNode (Read 720 times)
koichi_satoh
Jul 16th, 2024 at 8:29am
As shown in the attached image, is there any way to display tree-structured data hierarchically using ContainerNode other than manually specifying Bounds?
I would like to create a layout without complex calculations, for example by using MindFusion.Diagramming.Layout, without having to implement logic to adjust the size of the parent ContainerNode according to the number of child ContainerNodes.
Re: I want to lay out a hierarchical structure using ContainerNode
Reply #1 - Jul 16th, 2024 at 8:35am
This looks like the TreeMap sample project. Try the TreeMapLayout class shown there.
MindFusion
koichi_satoh
Reply #2 - Jul 17th, 2024 at 8:05am
Thanks to you, the problem has been solved.
Thank you very much.
