Normal Topic Diagramming for JavaScript, V4.4.4 (Read 604 times)
Jul 25th, 2024 at 9:53am
Version 4.4.4 is a maintenance release containing several fixes and customer-requested features:
New mouse events
  • nodePointed event has been replaced by a set of more specific events: nodePointerEnter and nodePointerLeave are raised when the mouse pointer respectively enters or leaves the boundaries of a node. nodeHovered fires if the pointer rests over a node for hoverDelay milliseconds.
  • linkPointed event has been replaced by a set of more specific events: linkPointerEnter and linkPointerLeave are raised when the mouse pointer respectively enters or leaves the boundaries of a link. linkHovered fires if the pointer rests over a link for hoverDelay milliseconds.
  • Enable the autoDeleteChildren property to automatically delete child nodes when a container is deleted.
  • Angular bindings updated to Angular 18.
  • Fix for selected property setter of DiagramItem not immediately reflecting assigned value due to async calls.
  • Fix for custom Shape definitions not setting the id property.
API changes
  • linkPointed and nodePointed events replaced by linkHovered and nodeHovered.
Updated scripts are also available as @mindfusion/diagramming NPM package.
