Normal Topic Diagramming for Windows Forms, V7.0.3 (Read 669 times)
Jul 18th, 2024 at 7:33am
We have released version 7.0.3 of FlowChart.NET. It contains the following new features and improvements:
New mouse events
  • NodePointed event has been replaced by a set of more specific events: NodePointerEnter and NodePointerLeave are raised when the mouse pointer respectively enters or leaves the boundaries of a node. NodeHovered fires if the pointer rests over a node for HoverDelay milliseconds.
  • LinkPointed event has been replaced by a set of more specific events: LinkPointerEnter and LinkPointerLeave are raised when the mouse pointer respectively enters or leaves the boundaries of a link. LinkHovered fires if the pointer rests over a link for HoverDelay milliseconds.
  • Set the AutoDeleteLinks property to false to prevent deleting links along with a node they connect, and disconnect the links instead.
  • DividerPen property added to ContainerNode, TableNode and TreeViewNode classes. It lets you customize the appearance of the divider line drawn between a node's caption bar and content area.
  • Fix for custom DoDragDrop calls not working if allowedEffects argument is set to Move.
  • Fixed label placement when SetLinkLengthPosition is called with 1 as argument value.
  • Fix for ExteriorBrush not used when drawing to interaction back buffer.
API changes
  • LinkPointed and NodePointed events replaced by LinkHovered and NodeHovered.
Updated assemblies are also available as MindFusion.Diagramming NuGet package.
