Normal Topic Non Rotatable Label for Shapenode in .net (Read 701 times)
G_G
Aug 7th, 2024 at 7:50am
Hi I'm trying to have a shapenode in my diagram that has a label centered below it that is rotatable without the label changing position or orientation. I cant figure out how.
I know node.text can be set to not rotate but i cant position it below the node outline
If at all possible i would like to avoid using a dedicated textnode for this because i would have to change a lot of code to do so.
Does anyone know a solution to this?
Re: Non Rotatable Label for Shapenode in .net
Reply #1 - Aug 7th, 2024 at 9:34am
If you don't mind using a custom class, you could override the Draw method:
class ShapeNodeEx : ShapeNode
	StringFormat labelFormat = new StringFormat
		LineAlignment = StringAlignment.Near,
		Alignment = StringAlignment.Center
	public override void Draw(IGraphics graphics, RenderOptions options)
		options.EnableText = false;
		base.Draw(graphics, options);
		options.EnableText = true;
		var textRect = GetRotatedBounds();
		textRect.Y += textRect.Height + 1;
		graphics.DrawString(
			Text, EffectiveFont, Brushes.Black,
			textRect, labelFormat);
	public override RectangleF GetRepaintRect(bool includeConnected)
		var repaintRect = base.GetRepaintRect(includeConnected);
		return RectangleF.Union(repaintRect, textRect);
Otherwise you could probably push the text below node by setting TextPadding while RotateText is disabled, but would have to modify padding dynamically when node rotates.
G_G
Reply #2 - Aug 14th, 2024 at 6:10am
Thanks this solves this issue for us!
