Normal Topic Unable to Open vsdx file exported using Visio2013Exporter (Read 656 times)
wkchong
Aug 29th, 2024 at 6:20am
The version of the MindFusion.Diagramming.Export.Visio used was 6.8.6.450. Visio2013Exporter is not working as it's having issue when opening a vsdx file exported via Microsoft Visio.
It seems like the required template file, Visio2013.vxt is missing. Where to get the valid Visio2013.vxt template file?
Re: Missing Visio2013.vxt
Reply #1 - Aug 29th, 2024 at 6:39am
The installer copies the template to a "Redistributable" folder under the control's setup location. Visio2013Exporter looks for it in same folder as application's executable by default. You can change that by setting TemplatePath property.
