Normal Topic TextBlock Run causes crash in TemplatedNode (Read 724 times)
Joel D.
Sep 4th, 2024 at 7:03pm
I couldn't find other mentions of this on the forums.  It's is not a big deal, but I figured I would let you know:
In a DataTemplate for a TemplatedNode, I tried using a Run in TextBlock. But when I clicked on the text with the intention of dragging to move the node around, an exception was thrown.  I easily got around the situation by using "
" in the Text property of the TextBlock instead of the using Run and LineBreak items.
This is what I tried in the DataTemplate:
<TextBlock>
    <Run Text="Hello" />
    <LineBreak />
    <Run Text="World" />
</TextBlock>
This is what fixed it:
<TextBlock Text="Hello&#10;World" />
It was a System.InvalidOperationException that came from DiagramPresenter with the message: 'System.Windows.Documents.Run' is not a Visual or Visual3D.
Re: TextBlock Run causes crash in TemplatedNode
Reply #1 - Sep 5th, 2024 at 11:22am
New package here should fix that -
https://www.nuget.org/packages/MindFusion.Diagramming.Wpf/4.1.3-alpha
Joel D.
Reply #2 - Sep 5th, 2024 at 10:38pm
Fixed, thanks!
