Normal Topic Diagram export (Read 551 times)
BigWander1
Diagram export
Sep 26th, 2024 at 3:28am
I have issue with exporting diagram with SVG node. After applying `SvgExporter.Export` method, lines in SVG file becomes solid if they have different style (Dashed line, Dots line etc). Attached project has `3.9.5` version, but this issue occurs on latest `4.1.3` version. You can see this behaviour and read my suggestions in `README.md` file in attached project.
Re: Diagram export
Reply #1 - Sep 26th, 2024 at 2:50pm
New build here exports custom dash styles -
https://www.nuget.org/packages/MindFusion.Diagramming.Wpf/4.1.4-beta
