Normal Topic Mindfusion types in React (Read 252 times)
Kamil
Oct 4th, 2024 at 12:22pm
Hi there! I'm using mindfusion in React. Here is the way that I import the library:
Code (Javascript)
import * as mfDiagramming from '@mindfusion/diagramming';
Then I use it like that to create a diagram:
Code (Javascript)
    const diagram = new mfDiagramming.Diagram();
The problem is, that when I'm hovering on "Diagram()" in my IDE, the types are not resolved properly. It displays: "any". Please see my first attachment.
The second attachment shows the information that I get when I hover over mf import.
Could you advise me on how to achieve proper types for mfDiagramming object?
Online
Re: Mindfusion types in React
Reply #1 - Oct 7th, 2024 at 7:32am
Apparently nodejs changed how typings should be defined (https://www.kravchyk.com/typescript-npm-package-json-exports/). For time being try editing @mindfusion/diagramming/package.json in your npm package cache, replacing the export section with this:
"exports": {
      "import": {
        "types": "./diagramming.d.ts",
        "default": "./dist/esm/diagramming.js"
      "require": {
        "default": "./dist/cjs/diagramming.js"
We'll publish a small update with that soon.
Kamil
Reply #2 - Oct 7th, 2024 at 9:32am
Thank you! I can see the types now Smiley
