Normal Topic Visual Basic Power Packs controls LineShape (Read 1971 times)
Bernard
Oct 9th, 2024 at 3:09am
I am evaluating to buy Winform pack. Is there any line component that i can put it in winform like Visual Basic Power Packs controls LineShape?
Re: Visual Basic Power Packs controls LineShape
Reply #1 - Oct 9th, 2024 at 7:06am
If you've found our pack because of the VB.Compatibility-like file/dir listboxes, our developers implemented them only because found it easier than redoing sample projects that relied on the deprecated controls Smiley Other than these, we are not generally trying to replicate VB UI controls.
At this time closest we have to PowerPack's ShapeContainer + LineShape/OvalShape/RectangleShape controls is the DiagramView control. You can add DiagramLink objects to the diagram to display lines and curves, setting their Shape and ControlPoints properties. DiagramLink is mostly used as connector between nodes, but there's CreateDiagramLink method and link constructor overloads that take point arguments, letting you create simple unconnected lines.
Bernard
Reply #2 - Oct 16th, 2024 at 12:11am
Ok. Thank you for helping.
