Normal Topic React: Error while importing the shape library (Read 433 times)
Kamil
Nov 21st, 2024 at 11:29am
Hello! I'm trying to import shape library in my react code:
Code (Javascript)
    const library = new mfDiagramming.ShapeLibrary([]);
    library.loadFromXml("myPath/assets/customShapes.xml");
The result is an error produced by mindfusion (please see the screenshot).
Could you advise me on how to resolve this problem?
Re: React: Error while importing the shape library
Reply #1 - Nov 21st, 2024 at 12:47pm
Please attach the xml file.
Kamil
Reply #2 - Nov 22nd, 2024 at 8:20am
Sure, here's the file.
Reply #3 - Nov 25th, 2024 at 11:54am
New scripts here should load the shape library -
https://mindfusion.eu/_beta/jsdiag45.zip
1. JavaScript version did not have any support for TextArea elements in the custom shapes. Our developer's implemented initial TextArea parsing, but only for rectangles. For arbitrary polygons we'd also have to implement the PolygonalTextLayout property from our desktop controls, but that won't make it for the v4.5 release. Until it's available, you might want to create a separate shape library for JS version with smaller TextArea rectangles; otherwise the library arranges text in the TextArea's bounding rectangle and might cover some parts of the shape you would not expect.
2. We can see one of the EfficiencyCurve shape line segments drawn at incorrect coordinates. Our developer will fix that for the v4.5 release (hopefully available later this week).
Kamil
Reply #4 - Nov 26th, 2024 at 11:26am
Thank you for the explanation and the file.
We decided to wait until the fix is ready on npm. So, did I understand correctly and v4.5 will not crash while loading my file?
Reply #5 - Nov 26th, 2024 at 12:38pm
V4.5 won't crash, but you might have to modify the text area definitions in your online version, to adjust for the missing polygonal-text-layout support. At this time the diagram will arrange text inside bounding rectangle of the text area coordinates, and so might cover some parts of the node that are not covered in desktop version.
Kamil
Reply #6 - Nov 27th, 2024 at 8:28am
Ok, thank you for clarification Smiley
Reply #7 - Dec 2nd, 2024 at 2:01pm
that's now available on npm -
https://www.npmjs.com/package/@mindfusion/diagramming/v/4.5.0
Kamil
Reply #8 - Dec 3rd, 2024 at 8:38am
Roger that! Thanks Smiley
