Normal Topic Diagram default scale (Read 173 times)
Bbuzz
Dec 4th, 2024 at 9:14am
I am creating a ShapeNode in a DiagramView:
.createShapeNode(100, 100, 20, 10)
When I look at the result on screen, all dimensions are scaled for some reason. E.g. the resulting node on screen is not 20 pixels wide but 76.
Checking my diagramview instance, I see it has a _scale property with a value of 3.78, which explains the discrepancy.
But where and how is that scale setting set ? I am not doing it. And how would I set it to 1 ?
Re: Diagram default scale
Reply #1 - Dec 4th, 2024 at 9:43am
The scale comes from Diagram.measureUnit property, whose default value is Millimeter. You could change it to Pixel, but would also have to adjust some size properties, such as adjustmentHandlesSize, gridSize, etc.
Bbuzz
Reply #2 - Dec 4th, 2024 at 10:42am
Can you clarify what "Diagram" is in this case for me to do "Diagram.measureUnit" ?
My code just does:
Code (Javascript)
var myDiagramView = MindFusion.Diagramming.DiagramView.create(document.getElementById("diagram"));
var diagramNode = myDiagramView.diagram.factory.createShapeNode(100, 100, 20, 10);
myDiagramView does have a measureUnit property, and in my case it returns "6". I don't know what that means.
But I assume you mean something different with "Diagram".
Reply #3 - Dec 4th, 2024 at 11:18am
Your Diagram instance is returned by DiagramView.diagram member (through which you also create nodes). E.g. if using the namespaced scripts:
myDiagramView.diagram.measureUnit = MindFusion.Drawing.GraphicsUnit.Pixel;
https://www.mindfusion.eu/onlinehelp/jsdiagram/Model_View_Architecture.htm
Bbuzz
Reply #4 - Dec 4th, 2024 at 11:57am
OK understood, values now match what I see on-screen.
Thanks Slavcho !
