Normal Topic Key styling (Read 1886 times)
TuanLe
Key styling
Nov 26th, 2024 at 3:33am
Could I customize the style of a specific button?
For example in my use case, I would like to have a specific theme for the Enter button only.
Thanks.
Re: Key styling
Reply #1 - Nov 26th, 2024 at 6:28am
If you already have a custom template for SpecialKey, try adding a DataTrigger to it:
<DataTrigger Binding="{Binding VirtualKey}" Value="13">
with property setters you need to customize for Enter inside.
TuanLe
Re: Key styling
Reply #2 - Nov 26th, 2024 at 7:03am
Thank @Slavcho
I saw that we have no property related to the background/foreground in the Key object.
So is there any way that I can update the background of the Key at runtime?
I have the use case that the background should be changed based on some runtime conditions.
Re: Key styling
Reply #3 - Nov 26th, 2024 at 7:15am
If you can describe these conditions using a DataTrigger, set x:Name of your Border or Rectangle that renders the key background, and then the trigger's setters could specify TargetName:
<Setter TargetName="backRect" Property="Fill" Value="..." />
Re: Key styling
Reply #4 - Nov 26th, 2024 at 7:19am
Alternatively have your template render background specified by a WPF attached property, and then change the attached property's value when you detect the conditions.
TuanLe
Re: Key styling
Reply #5 - Nov 26th, 2024 at 7:32am
Thanks for your support @Slavcho
I will try both of them.
