Normal Topic System.ArgumentException: 'DashPattern value is not valid.' when exporting a diagram with arrow line (Read 191 times)
nullable
Nov 26th, 2024 at 1:34pm
In the last versions I noticed that I get a System.ArgumenException when trying to export diagram that contains a diagram link with arrow HeadShape. Try the attached project.
Online
Re: System.ArgumentException: 'DashPattern value is not valid.' when exporting a diagram with arrow line
Reply #1 - Nov 27th, 2024 at 11:20am
New build here should fix that -
https://www.nuget.org/packages/MindFusion.Diagramming.Wpf/4.1.4-rc6
nullable
Reply #2 - Nov 28th, 2024 at 10:12am
Thank you! This fix works as expected.
