Normal Topic MindFusion Java Pack 2024.R2 (Read 1502 times)
Dec 16th, 2024 at 9:42am
Version 2024.R2 is a maintenance release containing several fixes and customer-requested features:
MindFusion.Diagramming
  • Improved render quality of bitmaps assigned to node's Image property.
  • Improved render quality of Overview control.
  • The Brush property of pens is now serialized in binary and XML formats.
  • FreeFormNode objects now support rotation.
  • DividerPen property added to ContainerNode, TableNode and TreeViewNode classes. It lets you customize the appearance of the divider line drawn between a node's caption bar and content area.
  • Fix for setDiagram not repainting the view.
  • We have replaced the Windows -only shape designer tool with an online shape editor at https://mindfusion.eu/tools/shape-designer.html
MindFusion.Spreadsheet
  • New bringIntoView overloads let you specify alignment of the cell in current viewport.
  • Formula bar focus change fixes.
  • Fix for formula bar showing grouping separator in formulas.
  • Excelimporter cell border style fixes.
  • Excelimporter named style import fix.
  • Improved thread safety for server-side scenarios.
  • New DataBar element of ConditionalFormatType draws data-bars showing relative magnitude of cell values relative to other cells in the formatted range. Bars are drawn using the BarBrush property of IStyle.
  • DATEDIF function fix for calculating month difference.
MindFusion.Scheduling
  • Fixed overflow exceptions when working with large Duration values.
  • Fixed exception when reordering rows in resource view with CustomGroupType enabled.
MindFusion.Charting
  • SupportedLabels setter added to SimpleSeries class.
  • Fix for chart not subscribing to dataChanged event in some call-chain configurations.
  • Fixed 3D bar drawing glitches.
  • Fixed RadarChart drawing glitches.
  • Builder pattern implemented for Axis and AxisRenderer objects. Call their with and init methods to get respective builders.
MindFusion Virtual Keyboard
https://mindfusion.eu/JPack.zip
