Hot Topic (More than 10 Replies) Calendar Print (Read 1681 times)
Raeees
Calendar Print
Feb 6th, 2025 at 2:58pm
I would like to know if its possible to save the calendar as a png without displaying it in a JFrame.
Essentially i will be running the resourceView application on a server (no display) and i wish to know if its possible to save content from the calendar knowing i dont have a GUI. This is the line i use to get the graphics when i have a GUI and save it in the format i need, it cant be applied the other way around
Code (Java)
calendar.print(graphics, format,0);
Its probably a more common issue in java swing, so any insights in the request will be appreciated
Re: Calendar Print
Reply #1 - Feb 7th, 2025 at 7:28am
Try calling Calendar.createImage method and saving to png using ImageIO.
You might get HeadlessException setting up a Calendar instance on server. Our developers added a lot of checks for these into our diagram component (e.g. https://mindfusion.eu/Forum/YaBB.pl?num=1218051540), let us know if you encounter any with the calendar.
Raeees
Re: Calendar Print
Reply #2 - Feb 7th, 2025 at 4:34pm
Hi again,
it doesnt seem to work, isnt the object calendar depended on the GUI to save/print anything?
When i use the line ''calendar.createImage()'' in this line, i get
Code (Java)
BufferedImage bImg = calendar.createImage(true);
		if(ImageIO.write(bImg, "png", new File("SavePNG.png"))){
			System.out.println("saved image");
		else{
			System.out.println("image not saved");
i get this error
Error: java.lang.NullPointerException: Cannot invoke "java.awt.image.BufferedImage.createGraphics()" because "<local7>" is null
thanks again
Re: Calendar Print
Reply #3 - Feb 10th, 2025 at 8:40am
Apaprently createImage is getting null bitmap from base JComponent.createImage when calendar hasn't been added to the UI. This build adds some fall-back code to create the image explicitly when base returns null:
https://mindfusion.eu/_temp/JPlanner_createImage.zip
You must also call setBounds before createImage, or the calendar will pass zero values to the Image constructor, when not assigned size by a parent frame:
Calendar calendar = new Calendar();
calendar.setBounds(
	new Rectangle(0, 0, 600, 400));
BufferedImage image = calendar.createImage(...);
Raeees
Re: Calendar Print
Reply #4 - Feb 10th, 2025 at 3:41pm
Hey,
This was very much helpful but i am getting another issue regarding
Code (Java)
calendar.setViewport(calendar.getDate(), calendar.getEndDate(), true);
When i save the calendar, the viewport is not within the ''StartDate'' and ''EndDate'' i setup. is it because viewport is dependant on the container's size? Which in this case, i do not have because there is no GUI.
FYI, the new jar you provided does not include the fix you made in the old post
https://mindfusion.eu/Forum/YaBB.pl?num=1731680248/13
reply#13
Cordially.
« Last Edit: Feb 10th, 2025 at 5:15pm by Raeees »
Re: Calendar Print
Reply #5 - Feb 11th, 2025 at 12:23pm
That reaches a calendar.getGraphics() call, again returning null when not in the UI, and the view is left with some default values. Our developer will try to add fall-back handling later this week.
reply#13
It should be included. Are you sure you are seeing same exception stack trace (esp. the Calendar.mousePressed line if you are testing on server now)?
Raeees
Re: Calendar Print
Reply #6 - Feb 12th, 2025 at 3:39pm
That was an error from my part, it works and there is no exception anymore
I'll be waiting for the changes provided by your developper
Thanks again for the assistance.
Cordially
Re: Calendar Print
Reply #7 - Feb 13th, 2025 at 12:48pm
Try new build here -
Raeees
Re: Calendar Print
Reply #8 - Feb 18th, 2025 at 4:08pm
Hi, i still get errors
so just to go back through all the necessaries i need for this to work
- i set System.setProperty("java.awt.headless", "true");
- create the calendar, setBounds(0,0, 700, 400);
- calendar.setViewport(startDate, endDate, true);
- BufferedImage image = calendar.createImage(true, 700,400);
- i call ImageIO.write(...)
This still gives me the folllowing error.
Re: Calendar Print
Reply #9 - Feb 19th, 2025 at 9:29am
This build replaces a few more calendar.getGraphics calls -
If not working, please attach a test project reproducing the error.
Raeees
Re: Calendar Print
Reply #10 - Feb 21st, 2025 at 1:59pm
So far its working alright, but i need to know something. How do i disable displaying lanes that arent fully fitting in the chosen bounds. the purpose of this is to figure out where to break page when printing, some lanes are cut in half with this (as shown in the image). i tried using
Code (Java)
calendar.getElementBounds(CalendarElement.ResourceViewHeader,8).getBounds().getMaxY()
but this didnt work because it cannot tell when the lane is fully displayed or not.
Maybe adding another overloaded method for calendar.createImage() to include elementalBounds? this way we may be able to cut printing according to fully visible lanes
Cordially
« Last Edit: Feb 21st, 2025 at 7:14pm by Raeees »
Re: Calendar Print
Reply #11 - Feb 24th, 2025 at 2:52pm
Maybe implement a separate measure pass by calling calendar.setBounds with a very large initial height, and collect the ElementBounds.height values for each resource row, to know what area they would occupy if having infinite space. Then on second pass call setBounds with actual target image size, and implement pagination by exporting subsets of the resources whose total height is smaller than image height.
Raeees
Re: Calendar Print
Reply #12 - Apr 10th, 2025 at 2:40pm
Thank you for these solutions. i come with a different issue now. i wish to save the calendar onScreen and not the one on a headless server as before here. the issue i come across on is that , the calendar uses the JPanel bounds so i cant use calendar bounds.
I know i can use this line to save a full calendar image.
Code (Java)
calendar.createImage(false)
this line gets an image of the whole calendar and its resources, however my goal is to save the image on different pages and for that i could use this line to know where to break page not cut the lane in half.
Code (Java)
double hm = calendar.getElementBounds(CalendarElement.ResourceViewCell,i).getMaxY();
this time it doesnt work because its within JPanel bounds, cant acces all the elements bounds outside the panel
In short, i want to grab the full image generated by the calendar and cut multiple sub images from it, for that i need to know where to cut the lanes correctly. you can notice in the picture, all lanes outside the panel are 0
Cordially
Re: Calendar Print
Reply #13 - Apr 10th, 2025 at 4:09pm
Same Schedule can be displayed by multiple Calendars, so maybe you could still create a separate off-screen calendar, but assign the on-screen instance' Schedule to it (also copy the view settings), and then arrange it as in the server scenario to get those heights.
Raeees
Re: Calendar Print
Reply #14 - Apr 14th, 2025 at 3:29pm
for me to copy the view settings i would need to acces the setter for resourceViewSettings and itemSettings. i can only acces the getter.
my alternative would be to copy everything inside resourceviewsettings one by one but it would be preferable if i can use the setter.
Cordially
