Normal Topic Calendar Viewport (Read 74 times)
Raeees
Calendar Viewport
Mar 20th, 2025 at 12:18pm
am running through some issue i think. When i use ''true'' on the calendar.viewport as so
Code (Java)
calendar.setViewport(startDate, endDate, true);
The timeline doesnt keep its date format. i know the TimeUnit change base on resolution but it should keep its format. this is th current format i use for my top time line. However, as the image below shows, thats the format i get. is there a way around this?
Code (Java)
ResourceViewSettings res = calendar.getResourceViewSettings();
		res.getTopTimelineSettings().setFormat("EEEE, dd MMMM");
Regards.
Re: Calendar Viewport
Reply #1 - Mar 20th, 2025 at 4:08pm
Usually format strings don't make sense for a different unit, and the resolution-changing code resets them to appropriate defaults for the unit it selects ("mm" for TimeUnit.Minute etc). I guess we could check whether a timeline unit does actually change before resetting its format string, but you could reassign too after changing resolutions Wink
// setViewport ...
if (res.getTopTimelineSettings().getUnit() == TimeUnit.Month)
