Normal Topic Undo more than one changes at a time in diagram control - silverlight (Read 5551 times)
lightsundar99
Nov 15th, 2016 at 5:52am
Hi Stoy,
I am changing node and link position at a time. I want to capture and undo these changes.
How to do  that ?
Re: Undo more than one changes at a time in diagram control - silverlight
Reply #1 - Nov 15th, 2016 at 7:26am
Use the StartCompositeOperation and CommitCompositeOperation methods. Commands recorded between these calls are recorded as a single CompositeCommand instance in the undo history.
lightsundar99
Reply #2 - Nov 15th, 2016 at 9:20am
thanks for your reply..
please give me code snippet for this..
i am bit confused to use command when to use.
thanks
Reply #3 - Nov 15th, 2016 at 10:13am
Here's an example that offsets selected items and later undoes the movement as a single operation -
private void OnMoveSelection(object sender, RoutedEventArgs e)
	var dx = 10;
	var dy = 0;
	diagram.StartCompositeOperation();
	foreach (var link in diagram.Selection.Links)
		for (int i = 0; i < link.ControlPoints.Count; i++)
			var linkCmd = new ChangeItemCommand(diagram, link);
			var point = link.ControlPoints[i];
			point.X += dx;
			point.Y += dy;
			link.ControlPoints[i] = point;
			diagram.ExecuteCommand(linkCmd);
	foreach (var node in diagram.Selection.Nodes)
		var nodeCmd = new ChangeItemCommand(diagram, node);
		var bounds = node.Bounds;
		bounds.X += dx;
		bounds.Y += dy;
		node.Bounds = bounds;
		diagram.ExecuteCommand(nodeCmd);
	diagram.CommitCompositeOperation();
