Normal Topic Summary Values (Read 6080 times)
Daniell
Summary Values
Sep 7th, 2005 at 11:01am
Hi, I'm not quite happy to see the so called summary value Always drawn under my chart data. Any ideas of workaround?
Sometimes I just need to see the numerical axis, no decorations Grin
Dan
Iva
Re: Summary Values
Reply #1 - Sep 8th, 2005 at 7:25am
Hi Dan,
Possible workaround would be to add the desired summary as custom summary and specify an empty string as its description (check AddCustomSummary method).
I hope this works. Wink
Cisar
Re: Summary Values
Reply #2 - Sep 9th, 2005 at 11:56am
I'm having a trouble drawing vertical line at a given place in a horizontal chart... or is it a vertical char? Anyway, I want a line in the middle of the graphics. Could it be done with a summary? And how?
Iva
Re: Summary Values
Reply #3 - Sep 12th, 2005 at 4:43am
Cisar, you could try adding a custom summary value and setting the boolean SummarizeXData to the opposite of your chart's orientation e.g. for vertical charts set it to true; if the chart is horizontal set it to false (default value).
I hope this helps.
Cisar
Re: Summary Values
Reply #4 - Sep 12th, 2005 at 12:52pm
If I add several summary lines how can I set the brushes fo rthem so that each line is drawn in a given  color?
Iva
Re: Summary Values
Reply #5 - Sep 13th, 2005 at 6:41am
If you are drawing lines you should use SummaryPens.  Add the pens in the same order as you add the summary values. The MultiColored property should be true (default value) in order to see each line drawn with a different color.
