Normal Topic create Box/Table by protect user to copy/delete. (Read 2473 times)
suwit
Nov 5th, 2005 at 7:01am
i want to create Box/Table by don't want user to copy/delete but only can move it around . Is it posible to do this?
i have used "object.locked=true" but i cannot move it.
Thanks.
Re: create Box/Table by protect user to copy/delet
Reply #1 - Nov 5th, 2005 at 7:53am
To prevent users from deleting a box, handle the BoxDeleting event and set e.Confirm = false. That event is raised when the Del key is pressed, but not when deleting items programmatically.
To prevent copying or cutting items to the clipboard, remove the box from the selection before calling the CopyToClipboard or CutToClipboard method.
To prevent resizing the boxes, set
box.MnpHandlesMask = 256
so only the movement handle remains enabled. In version 4 syntax that will look like
box.EnabledHandles = Handles.Move
HTH
suwit
Reply #2 - Nov 5th, 2005 at 2:04pm
Thanks, it's work.
