Normal Topic More bug (Read 4526 times)
Supapong
Guest
More bug
Dec 5th, 2005 at 6:05pm
Bug
- Attribute Name will be capitalized. The program should not do this because the XML standard specified that the attribute name is case-sensitive.
- Text edit control will never show horizontal scroll bar
- Text edit control is too small. At least it should be resizable.
- Conflist between 2 edit mode, Inline editing and Dialog box editing, causes some error. In case you have so long content in an element, if you edit it in inline editing, all the text longer than those allowed to display inline will be removed after editing. You have to edit in the edit dialog box only. I suggest you remove function to edit a value of element inline. Also it makes user confused about clicking and selecting the value node. Make it clear to let user edit the value of element via the Edit dialog box only and by double-clicking on the value node.
Features
- There should be a way to copy and parse any XML entity across the files which are being edited in XML Viewer in different windows.
Re: More bug
Reply #1 - Dec 7th, 2005 at 6:58am
Ok, I am going to fix these over the weekend.
