Normal Topic Custom mouse behavior (Read 2075 times)
richardpopple
Jan 11th, 2006 at 9:14am
I'm looking to use MindFusion flowChart.Net as part of an app but I have a query about the user interface. We need to be able to set up the app so that, to create an arrow, the user left clicks once on a node and the arrow then remains attacted to the cursor, as the user moves it. To connect the arrow to another node the user left clicks over it. So far I've only been able to implement behaviour where by the user must hold down the left mouse button to connect arrows. Any help on how I might create this sort of behaviour would be appreciated.
Rich.
Re: Custom mouse behavior
Reply #1 - Jan 11th, 2006 at 9:54am
The only way I can think of to do that is to handle the BoxClicked and MouseMove events like this:
Arrow currentLink = null;
private void fc_BoxClicked(object sender, MindFusion.FlowChartX.BoxMouseArgs e)
  PointF mousePos = e.DocumentPos;
  if (currentLink == null)
    currentLink = fc.CreateArrow(e.Box, mousePos);
    currentLink.Dynamic = true;
    fc.Capture = true;
  else
    currentLink.Destination = e.Box;
    currentLink = null;
    fc.Capture = false;
private void fc_MouseMove(object sender, System.Windows.Forms.MouseEventArgs e)
  if (currentLink != null)
    PointF mousePos = fc.ClientToDoc(new Point(e.X, e.Y));
    currentLink.ControlPoints[currentLink.ControlPoints.Count - 1] = mousePos;
    currentLink.UpdateFromPoints();
    fc.Invalidate();
richardpopple
Reply #2 - Jan 11th, 2006 at 10:08am
Thank you,
Yes I think that will do what I want.
Cheers Rich.
