Normal Topic Node.Collapse (Read 2593 times)
MichalLaskowski
Node.Collapse
Apr 26th, 2006 at 8:30am
When i call Expand or Collapse diagram doesnt get TreeCollapsed and TreeExpanded events. Why?
Re: Node.Collapse
Reply #1 - Apr 26th, 2006 at 10:24am
Most events are raised only in response to users actions. You can call a common method from the event handler and after doing something programmatically if you need to execute the same code in both cases.
