Normal Topic Disabling Creating of  Boxes and Arrows (Read 2627 times)
Teun
Sep 6th, 2006 at 6:22am
I try to disable the creating of boxes and arrows.
with event RequestCreateArrow.
But this does not work in my case. As a workaround i coded the RequestAttachAroow event. This is working fine by not allowing the arrow to be attached. But it is quite annoying that the user could try. How could i resolve this?
I am using version 3.2.3
In my flowchart the only thing the user is allowed to do is double click and dragging boxes.
I include my Vb code for clarification.
Teun
Private Sub flwModel_RequestCreateArrow(ByVal arrow As FLOWCHARTLibCtl.IArrowItem, pbCreate As Boolean)
'Description:
'     Request Create Arrow event - prevent user from attaching arrow to a different
'       box
'Arguments: [IN]  arrow - the arrow being modified
'           [IN]  changingOrg - True if moving arrow start point, False if end point
'           [IN]  obj - Object arrow is to be attached to
'           [OUT] attach - True to allow modification of arrow, False to cancel it
On Error GoTo errHandler:
    Const strPROCEDURE As String = "flwModel_RequestCreateArrow"
    pbCreate = False
    Exit Sub
errHandler:
    If gobjError.ErrSet = False Then
       Call gobjError.SetError(Err.Number, Err.Description, mstrMODULE, strPROCEDURE, gstrCOMPONENT)
    End If
    mblnError = True
    Call gobjError.ShowError
    Call gobjError.ClearError
    Call subUnloadForm(Me)
End Sub
Private Sub flwModel_RequestAttachArrow(ByVal arrow As FLOWCHARTLibCtl.IArrowItem, _
                                       ByVal changingOrg As Boolean, _
                                       ByVal obj As Object, _
                                       attach As Boolean)
'Description:
'     Request Attach Arrow event - prevent user from attaching arrow to a different
'       box
    Const strPROCEDURE As String = "flwModel_RequestAttachArrow"
    attach = False
    Exit Sub
errHandler:
    End If
    mblnError = True
End Sub
Re: Disabling Creating of  Boxes and Arrows
Reply #1 - Sep 6th, 2006 at 6:39am
Set FlowChart.Behavior = bhModify. That will prevent users from drawing new boxes and arrows, but will let them select and modify non-Locked objects.
You can set arrow.AllowMoveStart and AllowmoveEnd = false to prevent arrows being attached to different objects.
Teun
Reply #2 - Sep 6th, 2006 at 7:02am
Hi
I tried the bhModify before and i t did not work. However now i saw the FireMouseMove was set to True.
Setting this to False everything is functioning as expected.
Teun
Reply #3 - Sep 6th, 2006 at 7:11am
The bhModify behavior does not depend on the FireMouseMove value. That should work even if FireMouseMove is true, unless you change the Behavior in the MouseMove event handler?
Teun
Reply #4 - Sep 6th, 2006 at 7:30am
I only have a MouseUp event.  Anyway things are working now as expected.
Teun
